Configure multicast stream limitation on a VLAN to limit the number of concurrent multicast streams on the VLAN. By limiting the number of concurrent multicast streams, providers can protect the bandwidth on a specific interface and control access to multicast streams.
You can configure the maximum number of streams independently. After the number of streams reaches the limit, the VLAN drops joins to new streams. A service provider uses this feature to control the overall bandwidth usage in addition to restricting users from attaching more than the allowed television sets to a link.
Configuration of multicast stream limitation is not supported on a node configured as the DvR Leaf within a DvR domain.
Enable multicast stream limitation and configure the maximum number of allowed streams to 8.
Switch:1(config-if)# ip igmp stream-limit Switch:1(config-if)# ip igmp stream-limit stream-limit-max-streams 8
Variable definitions
Use the data in the following table to use the ip igmp stream-limit command.
Variable |
Value |
<0-65535> |
Configures the maximum number of allowed streams on this VLAN. The range is from 0–65535 and the default is 4. |
